Duck tail, I think it's time
I want to change the whale tail on my 1988 911 to a duck tail. What's the best way and who has the best fitting duck tail?
Thanks |
As someone that recently did this on my 911 and has done so several times before, go Getty/MA Shaw or go home. Best bang for the buck and fitment has never let me down.
I just did this last month. John Holt at Hot Wheels here in Marietta, GA worked with MA Shaw on mine. John took the outer fiberglass part from Shaw and mated it to the steel frame of an original decklid. You get the fitment of steel and it is lightweight. John has a "mule" he uses to do the test fit. He will paint and ship.
http://forums.pelicanparts.com/uploa...1438037796.jpg http://forums.pelicanparts.com/uploa...1438037837.jpg http://forums.pelicanparts.com/uploa...1438037901.jpg |
I am waist deep in my ducktail fitment. My Getty is light, but fitment... needed work. Everything is in the eye of the beholder, and I have no comparisons, but mine has needed ~10 hours at the bodyshop to get a satisfactory (not perfect) fitment, and we are not there yet. Getty quotes 2.5 hrs fitment in in their manual... and this may be true for a good piece (not all are equal), and for someone experienced with both fiberglass and ducktails. For the rest of us...
If money is a concern, and you are risk adverse, I would get a Stratton (Sanjay) tail. The extra money and wait upfront, will be paid back in spades with easy and excellent fitment. Down side is weight (not a huge difference), and losing an original decklid. |
Just to be clear, I still have my original decklid. John will provide one.
If money is a concern, and you are risk adverse, I would get a Stratton (Sanjay) tail. The extra money and wait upfront, will be paid back in spades with easy and excellent fitment. Down side is weight (not a huge difference), and losing an original decklid.[/QUOTE]
+1 on Gary's (Sonjay) ducktails.http://forums.pelicanparts.com/uploa...1438058204.jpg |
http://forums.pelicanparts.com/uploa...1438078885.jpg
TRE. 8 hours of fitment? No. I think it needed two rounds of sand/primer though. It is fiberglass and very light. |
Stratton ducktail will still need fitting before paint, my experience. As someone else said, the look of the fit is very different and you may want to see it before finishing. Also remember you cannot use the lift cylinder with ducks. (Again my experience and mentioned by others). The push to hard all the time and lift one side.
All that and I still love the old school look and won't go back. Nothing but positive comments. |
If it's fiberglass it's trouble. They all need work. I know.
I really like the idea of mounting the fiberglass on an original metal lid. I would do that in a heartbeat. Richard Newton Buying a Porsche at the Monterey Auctions? |
Last point so people understand is that I notice on my Stratton ducktail, most of the flat decklid metal is removed leaving essentially a "picture frame" of metal to which the f'glass is attached. That picture frame provides some but not all of the original fit because its not nearly as rigid or heavy, thus still needs to be verified before paint.
Another vote for the MA Shaw. It might not be perfect, but neither am I.SmileWavy
http://i906.photobucket.com/albums/a...ps375a4d9a.jpg |
I'll try to snap a picture later if that helps but since it's all black it's hard to see the detail. And sorry the pictures I posted earlier aren't that good -- I have been too busy lately to get some good shots with the car in the sunshine. |
I have the mashaw and couldn't be happier with the build quality
Sent from my iPhone using Tapatalk |
Bought mine from Rennspeed, no problems with fitment but the paint shop had a lot of hours in finish, mostly small pinholes.
[IMG]<a data-flickr-embed="true" href="https://www.flickr.com/photos/gerb/19457437841/in/datetaken/" title="Untitled"><img src="https://farm1.staticflickr.com/365/19457437841_c2e7cfb3e4_z.jpg" width="640" height="480" alt="Untitled"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>[/IMG] |
I recently installed a Stratton ducktail, and wanted to mention here that the plastic grilles are a tight fit and require removal of some grille material to fit properly. Has anyone else with a Stratton experienced this?
The aluminum grilles fit great - which is what I prefer anyway, even on my '77. |
Here are the pics of the inside of the tail I promised.http://forums.pelicanparts.com/uploa...1438199877.jpg
http://forums.pelicanparts.com/uploa...1438199923.jpg |
Thanks for the pics!
Not necessarily so. Use one of the old worn out ones form a stock lid from your parts stash. They work great with a F/G duck; it holds up the F/G duck without that too much pressure on one side issue. Getty, out of the box to paint fit on this one. http://forums.pelicanparts.com/uploa...1438204472.jpg |
| All times are GMT -8. The time now is 12:33 AM. |
