Another "help identify ?" - Part 2
Starting to take on the AC. These two wires are in the smuggler box near the expansion valve. They are original with the bunge protectors but have been taped off by PO. The blower for the AC works and is wired so that's not it.
Thoughts ? Second pic has three connectors. The plain one on the lower right is the small under trunk light. The other 2 connectors are unknown. One has a red dot the other a green dot. Thoughts and thankshttp://forums.pelicanparts.com/uploa...1438040468.jpg http://forums.pelicanparts.com/uploa...1438040488.jpg |
The red dot / green dot connectors may be related to the trunk light ckt.
Red dot is for trunk light (up-stream connection) Green dot may be spare/unused or for side-light. http://forums.pelicanparts.com/porsche-911-technical-forum/544969-trunk-light-power-connector-ident.html |
and I believe the first pair are for the alarm horn (that I don't have either).
http://forums.pelicanparts.com/uploa...1438047879.jpg |
Got it, thanks Steely. I tried the red dot but no light - will check power and the bulb.
I hate hving unused connectors lying around - it's a pet peeve |
LOL - Re: pet peeve - Same here
| All times are GMT -8. The time now is 02:08 AM. |
