Gauge fogging
I have an 88 911 cab...almost anytime that I drive the car the two gauges on the left side...fuel/oil level and oil pressure/temp....fog up from the inside of the gauge....the other gauges never do this....
Is there a solution? Thanks |
I put a dehumidifier inside the car and leave it running for two three weeks, and never get fogging again.
Rescuer of old cars
Or you can remove the offending gauges, remove one of the gauge modules from the rear and slip one of those little desiccant packs inside the gauge. You know, the ones that always say, "Do Not Eat" on them. Even in the humid rainy season here mine never fog any more.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Fahren mit dem Wind.
Arne2, that's brilliant! I have the same left 2 gauge fogging on my 83 Cab. I am going to try this.
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net) Caregiver to: 1983 911 SC Cabriolet - Fahern mit dem Wind. (Moss Green Metallic over Champagne and Brown Leather) |
Vintage Motorsport
Brew Master
Welcome to the club! I never understood why the speedo and clock never fogged but the fuel, oil and tach on my car did. I was going to throw a desipack in when I cleaned the glass but forgot. Now I have really clean gauges that still fog. Oh well.
My indy told me the Porsche Factory solution back in the day (80's) was to drill a 5mm hole int eh bottom of that gauge. This provides sufficient air circulation to prevent fog....and as the hole is on the bottom moisture will not climb up the hole and into the gauge.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
