rockabillyjay's Avatar
Engine near death experience! Or; the best $21 ever spent
My 78SC almost died this weekend!
I drove into work on Saturday (about 30miles), and when I got in I noticed my car making a unfriendly noise. I've heard it described different ways, but the sound a bicycle makes when the chain is hitting the guard is what it reminded me of.
At the time I wasn't sure what it was. I removed the fanbelt to make sure it wasn't the alternator bearing on it's way out. It wasn't. Rather than risk it, I had it towed to California Porsches where I do all the work on my car.
Once there I gave it a listen with a stethoscope..defiantly coming from the chain tensioner..yikes!
Once I opened it up it was obvious BOTH chain tensioners failed. I could push them up and down with one hand. A good set was dug out of the used parts pile and I was back on the road in no time.
I couldn't (still can't) afford the oil fed upgrade kit..but luckily when I was getting this thing back on the road, I spent the $21 on the guard set. These little guys saved my motor!
If you are not running the oil fed tensioners, go put these on your motor NOW!
Porsche 911 (1974-1989) - Camshafts & Timing Chains - Page 2
CARS ARE FUN!
Old 08-13-2015, 09:36 AM
Under the radar
Trackrash's Avatar
+1 on chain guards. Yea, the oil does leak out of the old style tensioners over time....
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-13-2015, 10:04 AM
