-   -   Heat backdate question (http://forums.pelicanparts.com/porsche-911-technical-forum/876848-heat-backdate-question.html)
bob deluke 07-29-2015 06:34 PM
All,
Planning on backdating my heat and so far have removed blower motor and ductwork.
For those of you who have done this, what did you do with motor bracket? I plan on removing it, but a couple injector lines and a part for the WUR is attached to the bracket. I can fabricate a smaller support bracket to attach these lines to. Just wonder what others have done. The motor bracket is a kludge after all the other stuff is out of the engine bay. Any thoughts,pics appreciated.
vesnyder 07-29-2015 06:47 PM
I backdated my heat last Winter ('83 SC) with SSI's and a new M&K muffler. Did not do anything with the blower bracket. Had to tweak the ductwork and put in new oil lines.
timmy2 07-29-2015 07:56 PM
I just pulled it off. None of the lines need support after they go past the throttle bracket.
Here is what mine looked like before I went to EFI.
http://forums.pelicanparts.com/uploa...1438224935.jpg
bob deluke 07-30-2015 06:42 AM
Thanks Dennis, I did the same as you. Engine compartment much cleaner now
