Runnin on empty
acme911's Avatar
Schroth 4-Point Safety Harness
Hi,
Thought I'd share.
Found these on eBay today: Schroth 4-Point Safety Harness only $55!
These are Military spec. mine-resistant light armored vehicles.
So Figured they are safe enough for street. Can also use with crotch strap to make 5 point.
New Schroth 4 Point Safety Harness SL 36 9C | eBay
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff.
https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html
Old 07-29-2015, 04:57 PM
joe payne's Avatar
Sweet! and they're Mine Blast proven!
jtp911
Old 07-29-2015, 06:07 PM
faverymi's Avatar
How and where in the car would you attach the upper shoulder straps?
It's going to need something else but what??
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 07-30-2015, 03:01 AM
moneymanager's Avatar
Careful if you think you want to use them on the track. They need to be wear-dated. No mention of that and I can't see in the pics.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 07-30-2015, 06:59 AM
Cajundaddy's Avatar
Well I can't really recommend that harness for street or track. See Schroth installation requirements and crash testing for specifics. In short, a 5pt harness used without the sub strap tends to cause submarining in a head-on collision. The driver is then effectively cut in half at the waist. Several on-track incidents with outlaw track day organizers have resulted in exactly this sort of fatality.
Schroth does make an ASM 4pt system that when installed correctly prevents submarining. It is approved for use with some legit track day groups.
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 07-30-2015, 07:57 AM
Cory M's Avatar
I wouldn't want to click each belt in separately on the street, that would get old. Any thoughts on the Racetech 4 point belts? They look very similar to the Schroth 4pt Rallye Cross. What exactly is different in the "ASM" belts that makes them prevent submarining?
Clubman 4-point : Racetech USA
Old 07-30-2015, 08:28 AM
Cajundaddy's Avatar
asm - Welcome to SCHROTH Safety Products, Germany
english.schroth.com/racing/technology/asm.php
The SCHROTH asm® system offers an unique safety advantage for 4-point harnesses. asm® is the acronym for anti submarining. The risk to submarine ( sliding ...
When installed and used correctly, the ASM harness induces a twist at the shoulders. This anchors you in the seat and acts more like a 3pt in a frontal collision. This has been thoroughly tested and is a pretty good solution with an approved seat and harness bar. I don't think it is compatible with a HANS device though. Must read all the mice type on safety gear to make sure it works as designed.
Old 07-30-2015, 08:46 AM
Cory M's Avatar
ASM stands for Anti-SubMarining. It's an extra flap of material sewn into the inboard shoulder belt that prevents you from sliding underneath the lap belt. In a 4 point harness made by some other company, the two shoulder straps restrain your upper body equally. They keep your chest from moving forward. However, this also pulls up on the lap belt and allows your accellerating pelvis to slide under the lap belt and cause serious damage to your stomach and intestines. With ASM, one of the shoulder belts will elongate at a different rate which will force your pelvis down into the seat cushion. Upon rebound, you will be placed back in an upright position with the belt correctly placed over your body.
Old 07-30-2015, 01:57 PM
saving a few bucks to get an unsafe product in a 911 is a pretty weird idea.
Old 07-31-2015, 10:24 AM
Runnin on empty
acme911's Avatar
How and where in the car would you attach the upper shoulder straps? Rear seat area
It's going to need something else but what?? Harness Bar
Careful if you think you want to use them on the track. They need to be wear-dated. No mention of that and I can't see in the pics. Strictly street, 2013
saving a few bucks to get an unsafe product in a 911 is a pretty weird idea. How many of you are still using 50 year old seat belts? And have you priced a new set of Schroth belts?
Thanks for the feedback guys. Got them today and the German build quality is excellent. At the price I paid. if they turn out to be a chore to use, I'll ditch them and go back to a new set of stock belts.
Old 07-31-2015, 10:07 PM
Over here they would be illegal. For good reason.
Old 08-01-2015, 11:08 AM
Platinum Member
dad911's Avatar
Hope you aren't using with stock seats. Safety needs the complete package, check the schroth installation guides.
Old 08-01-2015, 11:43 AM
