-   -   Need 6 Pin Connector/ Plug for 3.2 (http://forums.pelicanparts.com/porsche-911-technical-forum/877486-need-6-pin-connector-plug-3-2-a.html)
petercory 08-03-2015 05:16 PM
Both the 6 pin Male Connector plug at the rear (clutch end) of the 3.2 engine that connects to a 6 pin female connector attached to the shock tower X member are broken and I'd rather replace them with originals instead of a Deutsch Connector plug. does anyone know the Part numbers of both plugs pictured here?http://forums.pelicanparts.com/uploa...1438647337.jpg
gazzerr 08-03-2015 06:01 PM
Talk to timmy2 - he can sort you out.
timmy2 08-03-2015 06:25 PM
No I can't. I don't have them on hand, nor do I know the part number for the 3.2 as I haven't had them in my hands for the DME.
He already contacted me before making this post and I suggested Deutsch connectors.
If it was a 12 pin I could help him, but it is a six pin that I haven't researched. May even be in the PET???
timmy2 08-03-2015 06:41 PM
Ok, '89 PET shows a couple of 6 pin connectors on page 438 of 506 items 16 and 17
Part numbers are 91161286801 and 90161286702
Don't know if those are it, but they look correct.
petercory 08-03-2015 07:36 PM
Thanks again for all your help Dennis!!
gazzerr 08-03-2015 07:42 PM
You did sort it! :).
petercory 08-05-2015 04:41 PM
One of the plugs is NLA and no inventory shows available anywhere in my local dealers search; I guess I'l have to install a Deutsch connector plug.
LM3929 08-06-2015 11:02 PM
I may have both, I will check tomorrow
Lorne M.
petercory 08-08-2015 10:55 AM
Thanks lorne!!
LM3929 08-09-2015 09:51 AM
I only have the male end, Sorry
Lorne M.
Pazuzu 08-09-2015 03:08 PM
Didn't I send a 6 pin one to you once? It looks like the same 6 pin that was 1980 specific (they went to the 12 pin for 81-83).
If I never sent it I'll scrounge around, I must still have it.
timmy2 08-09-2015 04:26 PM
Hi Mike,
I have just the bottom piece of the female connector for the 80 Lambda. The one I have is broken at the locking tabs for the lid. :(
The photos he sent me look completely different for the 3.2 harness. Without having them in hand I can only guess.
If he sent me all 4 pieces of the connectors, even broken, I could probably make molds and cast new ones. It would take about a week or so though....
petercory 08-10-2015 05:14 AM
The Male End on mine is the one that's in the worst shape, can I buy the male end from you? If so please PM me your Paypal Info.
grahamkissack 08-10-2015 07:59 AM
I also have broken the identical connector and the female end is completely disintegrated leaving the hot posts exposed. Does Pelican sell the other connector?
http://forums.pelicanparts.com/uploa...1439218680.jpg
LM3929 08-10-2015 10:18 AM
Sure, pm me your info and I will send it to you for the cost of postage.
Lorne m.
timmy2 01-15-2016 11:42 AM
Good news, I found a source for new ones finally.....
Same as for earlier lambda 6 pin connectors as well. (1980?)
More info here:
http://forums.pelicanparts.com/8958861-post391.html
