H4 headlights
Hi looking to upgrade to h4 headlights on my sc , can anyone tell me the best place to buy them? Are they all the same ? I see them from $500 to $1200 , anything I should avoid
Thanks in advance
Old 08-04-2015, 05:31 PM
MBAtarga's Avatar
The host here (Pelican) sells them!
Mark
'83 SC Targa - since 5/5/2001
Old 08-04-2015, 07:03 PM
Senior Member
Jdub's Avatar
Bought my set here at Pelican who advised on bulbs, relay kit, etc. Can't go wrong.
'78 Targa | WANTED TO BUY - NORTON COMMANDO PARTS - PLS MESSAGE.
Old 08-04-2015, 07:09 PM
If you're going from sugar scoops to ROW type H4's it will still be 600-800$ from pelican, correct me if im wrong?
Old 08-05-2015, 01:38 AM
RFP RFP is offline
RFP's Avatar
I just received my pair of superbly restored German H4s from John Audette (find him here: H4s Restoration & Refurbishment | Audette Collection: The SWB 911 Light Resource ). Beautifully done and priced competitive with the current crop of Czech lights.
Rob
Maverick Region PCA, Fort Worth/Dallas area
1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249
1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD
1982 924 White, SOLD long ago
1966 912 Red, SOLD, totaled a week later by its new owner
Old 08-05-2015, 08:01 AM
thanks guys!
Old 08-05-2015, 08:35 AM
in case you don't already know, you'll need a few extra bits, new seals, the 2 special screws, and a outer trim ring (Paintable). You don't have to have the ring but it covers the adjusting screws and looks cleaner. The Porsche PET diagram has all the details if you haven't already looked at it.
Good luck - it will be sweet once you're done. Be very careful to ensure it's installed and seated properly - not Porsche's most robust mounting design .
Dave
1985 Factory Turbo-Look Coupe
2011 Cayman S
2012 Audi S4
Old 08-05-2015, 11:32 AM
targa82 -- if you're simply looking for the better illumination provided by european headlights, you can switch to "drop-in" round h4 headlamps that will fit into your existing sugar scoops for a fraction the cost of the 911-specific H4 assemblies. FYI
Regardless, if you haven't done so already, its also a great idea to add a headlight relay to your circuit -- as delivered from the factory, all the headlight current flows through the turn signal switch (which also selects high beams) and the heat generated by this current is a relatively common failure point. Installing a relay takes the current away from the turn signal. Our host sells a good headlight relay kit
Old 08-05-2015, 12:19 PM
