New kid in town
How do you clean your Motive?
How do you clean your power bleeder when you’re finished. I found getting in to all of the little nooks and crannies next to imposable. Is there a cleaning solution that I can run through that wont have a negative reaction with the brake fluid?
I wish I still had 9111113443... Last edited by 71T Targa; 11-18-2002 at 07:26 AM.. |
Brake fluid, like Ate Super Blue are glycol based and are soluble in water. I clean my Motive with water and let dry thoroughly.
Lothar of the Hill People Gruppe B #33 The Founders would vomit at the sight of the government that the People's lack of vigilance has permitted to take hold. |
Friend of Warren
Same here, just wash everything out in hot water and let it air dry.
Kurt V No more Porsches, but a revolving number of motorcycles. |
New kid in town
I was worried about using water as the brake fluid is hydro-scopic. (sic) I guess as long as I get it completely dry…
Thanks to all.
I wish I still had 9111113443... |
Hello,
I always use CHEMTOOL Break cleaner after each use. It works great! Spray and Wipe.. done Jorge (Targa Dude)
I just clean it in the sink with water, like the others. I also take it apart somewhat (take the hose off, etc) to let it dry.
I might not do that if I were planning on using it the next day or something, but given that it probably goes a year or so between uses, there is plenty of time to completely dry out! |
Sorry, a little off topic, but what is the best step by step procedure for using the Motive to bleed brakes? I've read at least two different ones.
Bill Krause We don't wonder where we're going or remember where we've been. |
