-   -   Cat bypass with o2 (http://forums.pelicanparts.com/porsche-911-technical-forum/878007-cat-bypass-o2.html)
RhodeIslandSC 08-07-2015 12:45 PM
Cat bypass with o2
1987 02 sensor frozen no need for cat, what can I expect,installing Brush bypass
Targa Me 08-07-2015 01:02 PM
will probably run rich.
Bob Kontak 08-07-2015 01:02 PM
Expect a little less back pressure. A touch more favorable rumble. Maybe a few ponies.
Make absolutely sure flanges are sealed upstream of the sensor. I have used two factory gaskets with $8 muffler paste from the local store.
cwinters01 08-07-2015 01:58 PM
a lot more stink at start up. i liked the sound better with the cat bypass. i thought i could feel a little more oomph, but now having gone back to the cat for smog, i'm thinking no noticeable difference...
Reiver 08-07-2015 03:10 PM
A bit more noise and a bit more smoke/fumes on start up. You might get a few HP but only at WOT...most confuse the noise for HP.
If you notice a big difference it's because your cat has partially failed and is clogged.
You will lose a big hot spot next to your cam cover tho.
