-   -   Intermittent start problem (http://forums.pelicanparts.com/porsche-911-technical-forum/878250-intermittent-start-problem.html)
sf2oc911sc 08-09-2015 06:02 PM
Is there a switch or relay that prevents/allows you to start in gear vs in neutral on a '83 SC? I'm having this weird problem when going to start after a long (<30 min) run. I was in gear, no start. Battery charge at 12.6v when off, alternator was charging, so I slipped in into neutral and it started right up. Any advice or thoughts are greatly appreciated, thanks.
ossiblue 08-09-2015 06:11 PM
It's not clear from your post if by " no start" you mean that the starter motor runs but the engine won't fire, or the starter motor doesn't run at all. Can you clarify this for us?
sf2oc911sc 08-09-2015 06:37 PM
Starter did not run. Sorry.
Driven97 08-10-2015 05:09 AM
I just ran into a problem where after a long (4 hour) drive the car would not start.
I tapped on the solenoid and it fired.
I let it cool overnight, it fired.
I ran a 4 hour drive home, it wouldn't start.
Let it cool again, it fired.
For me it seems to be an open and shut case of heat affecting the starter solenoid. I ordered a new starter assembly, and it should show up at my house today.
ganun 08-10-2015 06:23 AM
To the original question....there is no relay or anything else related to gearbox or clutch and starter operation. Totally independent of each other.
sf2oc911sc 08-11-2015 03:37 PM
Let me know if replacing the starter resolves the problem. Thanks, those are the same symptoms I'm experiencing.
