| javadog |
08-11-2015 07:06 AM |
The only way to match this is to mix up a batch of paint (I'd suggest having the shop that will paint it also mix the paint) and spray it on a test panel (metal, primed with whatever primer you are going to use). You'll want the guy shooting the tail to be the one shooting the test panel. Once it is dry, look at it in several kinds of light. Direct sun, shade, etc. If it matches, proceed with painting. If not, proceed with changing the mix and do it again. You might find it matches in one lighting condition, and not others, so you have to pick your poison.
It might be helpful to find out what paint is on the car and use that same product.
I use a local shop that matches by eye with an endless supply of chips, then mixes their own paint.
JR
