-   -   SSI Smog Question (http://forums.pelicanparts.com/porsche-911-technical-forum/8790-ssi-smog-question.html)
Glen 10-02-2001 06:58 PM
SSI Smog Question
Hi All
Has anyone thought or tried to have a muffler shop run the two SSI exhausts thru a $70 universal PEP Boys Cat in the muffler space and use a supertrap or resonator tip to pass the visual on a CA Smog test? Would this set-up work for testing purposes?
campbellcj 10-02-2001 07:20 PM
Which car do you have? Such a setup might work OK...but I can't imagine that it would pass the Calif smog-nazi visual inspection in the least! Nothing about it resembles stock on a post-74 911. If the inspector knows 911's well at all, or has good pics to look at, I think he'd be onto it in no time.
Chris C.
73 914 2.0
70 911E Targa
campbell.chris@gte.net
Clark Griswald 10-02-2001 07:27 PM
There was an earlier post by someone who built a similar arrangement. Seems he past if I remember.
However...the sheet metal on SSIs make them look an awful lot like cats to someone not familiar with the car. Nudge nudge, wink wink.
