-   -   71 T ignition problem... (http://forums.pelicanparts.com/porsche-911-technical-forum/879003-71-t-ignition-problem.html)
burch 08-15-2015 07:20 AM
went for a drive yesterday, it was hot, got home, turned car off then tried to restart and nothing. Fuel pump was pumping and electric was working, but no start.
starter or switch?
E Sully 08-15-2015 07:46 AM
You can use a meter to check for 12V at the yellow wire on the starter while someone turns the key.
