-   -   81SC CIS part identification (http://forums.pelicanparts.com/porsche-911-technical-forum/879121-81sc-cis-part-identification.html)
Coastr 08-16-2015 03:20 AM
Need confirmation on parts here.
The bottom valve is the deceleration valve, or the AAV? I'm trying to troubleshoot an intermittent high idle (2100rpm), I've read a few threads and was experimenting with pulling the vacuum line but couldn't work out if I had the right one.
http://i1283.photobucket.com/albums/...pszjxqyvab.jpg
Flat6pac 08-16-2015 04:46 AM
The lower pod has a vacuum connection on the outside. Many times I find the line disconnected and plugged.
Bruce
Coastr 08-16-2015 04:56 AM
Yes, it has a vacuum line. Is it the deceleration valve?
gregoryp 08-16-2015 05:01 AM
Aav
That is the auxiliary air valve. Check out this web site. Has a great description of everything. 911 CIS Primer - Index
tirwin 08-16-2015 06:36 AM
The one with the vacuum line is the decel valve.
ossiblue 08-16-2015 08:07 AM
Here is another view of an engine similar to yours
http://forums.pelicanparts.com/uploa...1355294367.jpg
You can see the AAV and decel valves look nearly alike, but the decel valve has the vacuum port on the front. In your photo, you can see the port at the very right side of the valve, identifying it the decel valve. The two valves in the picture are in reverse location to yours--your upper valve is the AAV and the lower is the decel.
Coastr 08-16-2015 03:21 PM
Ah, thanks for this. The descriptions I have seen/read match your picture, with the decel valve on top, but mine has the decel valve on the bottom.
I wonder why mine would be around the wrong way then? I suppose someone might have a reassembled them incorrectly. If that is the case, then I wonder if that is causing an issue?
ossiblue 08-16-2015 06:25 PM
Here is a picture of a set up like yours, from a 1981 SC
http://forums.pelicanparts.com/uploa...1334266405.jpg
and a picture of how the devices are connected
http://forums.pelicanparts.com/uploa...1251500884.jpg
You'll notice both devices connect to the metal tubing, and both connect to a molded rubber fitting. In short, it wouldn't matter if the devices were switched as both are connected to the same vacuum system.
Coastr 08-16-2015 09:03 PM
Gotcha, thanks. I notice that last picture looks like it has had the 'crush' treatment for the decel valve.
Not sure if I am going to try plugging the vacuum or try the crush treatment.
turbo nut 08-16-2015 09:14 PM
Also check the that the advance is not sticking in the distributor.
Coastr 08-17-2015 05:00 AM
Any advice on how to do that?
Coastr 08-17-2015 06:51 PM
Bump in the off chance that someone can answer this Q
Bob Kontak 08-17-2015 07:12 PM
Your's is not on the wrong way, The decel is on the bottom. Without a doubt. Word to Your Mother, as Vanilla Ice says.
Lemmie get a pic.
Bob Kontak 08-17-2015 07:14 PM
Chill on this for now. You gots you some vacuum advance and mechanical advance. Both can be tested. You have a timing light?
Coastr 08-17-2015 07:22 PM
Actually I don't think I do. I did have once, long ago when the earth was green and children respected their parents. This is the way to test, with a timing light? Maybe I can find one somewhere.
Bob Kontak 08-17-2015 07:30 PM
Ossiblue's second pic is correct.
http://forums.pelicanparts.com/uploa...1439865009.jpg
Coastr 08-22-2015 03:40 PM
So I golf tee'd the vacuum line and the driveability of the car at low speed is transformed. It's like it had three flywheels in it before.
