Help. Need 930 transmisison fastener torque value
Hi, reassembling a 930 transmission after new syncros and a few other wear item replacement.
Can someone tell me the torque value for the: bearing retainer plate (is it the same as a 915?) input shaft main nut pinion shaft main nut Thanks |
Plate 16-18ftlb
30mm MS collared nut 160-170ftlb 20mm MS collared nut 120-130 ftlb 24mm Pinion collared nut 180-190 ftlb |
Thanks John.
I had 2 of 3 correct. I thought 110 for the 20mm nut. Always good to verify. Now I can finish it all up. |
| All times are GMT -8. The time now is 10:01 PM. |
