Borrow/rent your extra air pump in Denver
Looking for someone in the Denver area that has a air pump laying around to borrow/rent for the emissions check. Passes the sniffer test but not the visual for having one. Can come pick it up tonight with $$ and return this weekend!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 08-13-2015, 12:55 PM
Functionista
manbridge 74's Avatar
I have one off a 75 that I believe will work. But I'm in Colorado Springs....
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 08-13-2015, 05:00 PM
Sent PM
Old 08-13-2015, 05:13 PM
My other ride is a C-130J
RNajarian's Avatar
Sorry Mine is a little too far away too
Assuming the smog check guys in CO are no different than the guys in CA, the only way they will know your car has the smog pump is by the emissions sticker.
JUST WONDERING; Is there an emissions sticker (assuming for the same size/type motor as yours) that does not have the smog pump you could replace your existing one for? Did the European 930 have a smog pump? If not, what if you replaced that sticker with your current one?
When the smog check guy checks my engine in CA they always refer to the emissions sticker as a reference as to what equipment should be there.
Just a thought
Good Luck
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 08-14-2015, 03:59 AM
No emissions sticker.. but not to worry I went to another station and they passed me without one! Soo lucky Guy was pretty great there after explaining how the cat was tucked way up above the muffler he said he sees lots of them come through and didn't even look for the cat or open the lid to see if there was a air pump. Good weekend I would say!!
Just a thought
Good Luck
Old 08-16-2015, 11:54 AM
