-   -   Custom wheels-zero or negative ET (http://forums.pelicanparts.com/porsche-911-technical-forum/879394-custom-wheels-zero-negative-et.html)
hangar21 08-17-2015 06:39 PM
Ok Guys, 87 911 cab with (964) wide body kit?
I'm replacing 18" cup II wheels, both Front (27mm spacer) & Rear ( 51mm spacer) so I need your help to find a custom wheel builder. Be advised, I've email 2 guys from this blog & have received NO REPLYs! Please provide any info for custom wheels builders. I'd like to eliminate the spacer as much as possible?
Thanks,
Terry
Jim Dorociak 08-17-2015 11:00 PM
I custom build Speedline wheels. I have a set of Alessio and Daytona wheels. Jim jdorociak@gmail.comhttp://forums.pelicanparts.com/uploa...1439877166.jpg
http://forums.pelicanparts.com/uploa...1439877238.jpg
http://forums.pelicanparts.com/uploa...1439877329.jpg
http://forums.pelicanparts.com/uploa...1439877532.jpg
http://forums.pelicanparts.com/uploa...1439877599.jpg
hangar21 08-18-2015 05:14 AM
Jim,
Thanks for reply, I sent you an email.
Terry
