jwakil's Avatar
Are all the round relays interchangable?
Are the round relays for the AC and the fuel pump and other things in the trunk and engine compartment the same? I want to have a spare in case one goes out but are they different AMP ratings and if so, can I just get the highest rating one for emergencies?
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 08-18-2015, 09:10 PM
El Duderino
tirwin's Avatar
The black ones are all the same. The red fuel pump relay is different. At least that is the case for SC's.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 08-19-2015, 04:31 AM
^^This^^, and it's for all 911s from 76 onward.
The red relay is for the fuel pump and has an internal diode that prevents reverse electrical flow through the relay coil when the magnetic field collapses. You can use a red relay as a substitute for a black, but it is not recommended to use a black in place of the red unless it is an emergency. If you are thinking of carrying spares, buy each type.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 08-19-2015, 07:35 AM
BlueWing's Avatar
I have looked in the past but never found the specs of the black round relays. Anyone know what the current capacity for the contacts are?
Terry
79 SC Minerva Blue ROW
Non Sunroof Crank Window Coupe
3.0 SSIs, Backdated Heat
COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires
Old 08-19-2015, 07:52 AM
jwakil's Avatar
Well, sounds like for emergencies if I just get a red I should be fine.
Old 08-19-2015, 09:58 AM
OsoMoore's Avatar
Test your backup - I've had two go bad on me, and one right after replacing it. It led to plenty of hours of headache searching for the problem elsewhere because the new relay was erratic.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 08-19-2015, 11:55 AM
