-   -   A/C Low Pressure Post Location : 1985 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/879680-c-low-pressure-post-location-1985-911-a.html)
Patrick911 08-19-2015 06:37 PM
I am venturing into my friends 85 cabriolet A/C system. While I have owned, serviced three 944 cars for twenty years, some of the 911 design mystifies me.
I have done my own a/c work with sucess. For the 911 I ask:
1. Where are the high & low ports? (denso compressor..on the compressor itlself, I thought the rear facing port was low and the forward high)
2. Where is the receiver drier hiding?
3. Where is the low freon cut off safety valve? (in case I need to bridge it if there is zilch for freon so the compressor clutch will engage)
Thanks in advance folks.
Patrick
Bob Kontak 08-19-2015 06:43 PM
Dear Lord. Brace yourself, Patrick
Ronnie's.930 08-19-2015 07:07 PM
Patrick, Nippodenso compressor ports are marked D (discharge = high side) and S (suction = lowside), but regardless, the highside port has the hose connected to it that goes to the tail condenser.
The receiver/drier is in the front left wheel well, backside of wheel.
No OEM pressure switch, but if one was added at some point, it would either be in the vicinity of the high side port on the compressor (or inline with the short section of hose there), or in the vicinity of the receiver/drier.
wwest 08-19-2015 07:30 PM
Charging ports, converting to R134a.
Nostalgic AC - R134a Charging Ports - Fittings & Hose Kits
7/16" R134a high side adapter, pressure switch, 398 PSI compressor cutoff
Nostalgic AC - Binary Switch w/ R-134a Discharge Port 7/16" - AC Pressure Switch - Oil, System Flush & Switches
RED DOT Trinary pressure switch, 325 PSI compressor cutout. Extra element for fan/louver control.
Red Dot Corporation | Mobile HVAC |
wwest 08-19-2015 07:45 PM
1988 Carrera
http://forums.pelicanparts.com/uploa...1440038720.jpg
kuehl 08-20-2015 09:34 AM
Compressor service ports
http://forums.pelicanparts.com/uploa...1440088174.jpg
Drier in LH front fender behind tire
http://forums.pelicanparts.com/uploa...1440088202.jpg
Read the Mr. Ice Project
Neel 08-20-2015 10:59 AM
+1:eek:
kuehl 08-20-2015 12:02 PM
398 psi. off is too high
