Binary valve.
http://forums.pelicanparts.com/uploa...1440208242.jpg
^^^^^ Where is the source for this binary valve? Thanks in advance, Gerry |
Fitting.
So, I think I need the 90 degree hose fitting with the threaded adapter to accommodate the binary switch.
Thanks, Gerry |
I would bet that there is a pressure switch adapter that connects where you have gauge manifold high side connected.
Charlie Griffith (Kuehl) sells the complete compressor to condenser hose with the switch
installed. (the one in your pic!) https://griffiths.com/product/91157315003-comp-cond-with-pressure-switch/ |
| All times are GMT -8. The time now is 01:37 AM. |
