slotmeister
inner rim paint on Fuchs: how important is it?
I've seen a few posts debating the correct colour and type of paint for the outside (petals) and inside (i.e. back, inner circumference) of Fuchs wheels. But how important is it to have a coating of paint on the latter?
Reason I ask is that I had my front wheels off at the weekend, noticed a build-up (up to 1mm thick) of brake dust and grunge in that inner rim. Cleaned them out with water, Simple Green and a scrubbing brush. When done, I noticed that the surface colour was a washy, silvery-black; more like alloy coloured-in with a black marker pen, than an actual paint coating. No visible etching/porosity in the surface or anything, but does it need a proper coating in there? (I'm aware of not painting the lug-nuts area). |
Recreational User
Paint is just for looks on an aluminum wheel, so it's only as important as you decide it is.
slotmeister
Thanks, Dave. You've just saved me a Saturday.
Caveman Hammer Mechanic
http://corrosion-doctors.org/MatSelect/corraluminalloys.htm
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 08-26-2015 at 05:53 PM.. |
Banned
Fuchs are anodized from the factory, so they do already have a coating. Unless it has been polished away, you already have one of the most corrosion-resistant coatings on your wheels. Enjoy!
Rock chips, and other mechanical damages will negate that advantage, paint is easily touch up able. Brake dust can be quite corrosive, anodizing coupled with a few mils of paint is a great combo.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Recreational User
slotmeister
Guys, guys! I see merit in both options (paint/do nothing). As ever, am grateful for the breadth of knowledge and experience on this forum.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 08-27-2015 at 07:19 PM.. |
