OUCH --Clutch job needed
Car conked out on way to work this morn. 100,000 miles. 87 911. Towed to mechanic who said was about $2600 at first glance with the 30,000 done at the same time. He says it needs fork?? replaced and upgraded to brass one and probably the clutch too at this mileage. Needs to drop engine, blah blah blah Sound right???
g-50 upgrade of shaft/fork and replacement of clutch... add in 30k service... yeah, I'd say $2600 is not too far off the mark.
Dan Tolley 1987 911 Coupe The Owner's Gallery 2006 Audi A4 3.0q Cabriolet 2003 Ford F-150 XL Lumber and Trash Hauler. |
only about $500-$600 off the mark. kind of pricey!
Nobody
john, what is the standard shop time to just drop the motor only - no additional work?
bob |
It's only about $500-$600 off your mark John.
![]() I was quoted about $2k for just a clutch replacement (my neck of the woods) Add in the $250 for the Porsche factory fix, and 2-5 hours for labor + $$ for maint parts... That's why I figured $2,600 was not too far from reality. But yes, it is a bit high any way you look at it. ![]()
Author of "101 Projects"
Why don't you just buy the parts and do it yourself? Here are the instructions - it's not too difficult:
http://www.pelicanparts.com/techarticles/911_clutch_replace/911_clutch_replace1.htm -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Isn't the book rate for an engine drop and reinstall something like 6 or 9 hours? My old mechanic said he could drop an engine in 1 hour. So there is a lot of free money whenever they drop an engine.
Maybe John Walker can make a list of what he charges for common repairs so we can see when we are being hosed.
Neil '73 911S targa |
I have to keep posting this to encourage others to DIY their clutch job. Wayne is absolutely right. You can do this yourself for under $1000. Hell, for the fun and learning experience I got out of doing my own, I would have gladly paid $2000. BTW, this was my first engine drop and we did it in about 6 hrs., none of us having ever done it before. A few months later, Marcesq and I dropped his (just the two of us) in under 4 hrs. Check out below. It can be done!
Engine drop . . . day one
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Senior Member
I agree with Wayne. The reasons I perform these jobs on my own cars include:
Save Money Learn about the car Make sure the car is not damaged in the process Increases the length and width of my Johnson Seriously, the nimrods who work at shops, even dealerships, often break and scratch things, and just cover up the damage. A shop is free to charge the "book rate" regardless of whether it actually took them that much time. Time is money for John. So, John is fast. John is real fast, because he knows exactly what he is doing and he wastes no motions at all. I believe John shares those savings (savings that accrue from his acquired efficiency), with his customers....but I figure he benefits from that efficiency more than the customer, and that is fair. In other words, if he does a job in one hour that the book says takes seven, then perhaps he charges for five hours. Good work is expensive, but worth every single penny.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
yes, you can't give it away if you run a business. the overhead is too high. i try to stay equal with the rest of the locals so i don't get a rep as being expensive. yes, i can do a clutch job in a couple of hours if everything goes right, but charging for straight time would put me out of business quickly, so i charge what i think is reasonable without feeling like i gouged someone. most shops around here feel the same. book times tend to be unreasonable, so i don't even look.
