HELP IS NEEDED!!! Exhaust Stud Chamber
I purchased my first (1982) 911sc over the winter knowing a few items needed attention (exhaust studs and broken head studs.)
Previous owner extracted several exhaust studs by drilling. When cleaning exhaust stud chamber with compress air, I can feel air coming out the other side of stud chamber.
It appears that a pilot hole was drilled too deep and went through.
Please help!!!!
What are my options?
Do I need to replace?
Do I leave as is and insert new exhaust stud?
Old 09-08-2015, 06:43 AM
patz's Avatar
Case savers or helicoils.
I will use a FAF when I am dying of thirst
Old 09-08-2015, 07:01 AM
Thank you Patz,
I was able to re-tap and insert stud.
Was wondering if any other damage / issues can be caused. The drill hole penetrated to the other side.
Old 09-08-2015, 07:36 AM
patz's Avatar
You can fill and drill but typically requires pulling the head.
Old 09-08-2015, 07:39 AM
