1986 Carrera Headlights Out
Headlights worked in the morning, then a long spirited drive, and no headlights in the evening. Parking lights and license plate lights are fine. No headlights, fog lights, or high/low beam action. High beam and low beam fuses were changed with hopes that may have been it... No joy. I'm stumped. Would appreciate advice!
Old 09-22-2015, 07:48 PM
MrScott's Avatar
So it's working as if the headlight switch weren't out all the way?
Maybe the headlight wire on the back of the switch came loose - or the switch broke.
1980 911SC
Old 09-22-2015, 08:29 PM
BHP231's Avatar
I had headlight problems, on, off, flickering on and off, you name it.
After fiddling with the main light switch and high beam stalk I installed new ones bought from our host and the problem was fixed.
Relatively easy installs for both, and worth the effort to know I could drive somewhere and get home in the dark safely.
1971 911T
1985 944 manual road car
1983 944 race spec car
2009 997.2 Carrera PDK) gone but not forgotten)
1988 Carrera Targa Euro Spec (gone by not forgotten)
Old 09-23-2015, 03:35 AM
I bet you that your high/low stalk is bad.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 09-23-2015, 06:15 AM
Thanks for the responses. It's certainly possible the wire on the back of the switch came loose. Something to check. I suspect it is the high/low beam stalk. As I am a newbie to Porsche ownership, I'm a little concerned about digging into the electronics. Overly cautious?
Old 09-23-2015, 10:18 AM
RETIRED
Joe Bob's Avatar
Do you have high wattage bulbs and/or the recommended relays to keep your stalk from melting down?
2012 ML350 3.0 Turbo Diesel
Old 09-23-2015, 11:15 AM
make sure these plugs under the dash are fully seated.
Old 09-23-2015, 12:52 PM
Same old bulbs but no relays. Suggestions?
Old 09-23-2015, 07:14 PM
patz's Avatar
Replace the stalk or the switch and install a relay kit to keep it from frying again.
I will use a FAF when I am dying of thirst
Old 09-24-2015, 08:14 AM
Short video of replacing the headlight switch here. https://www.youtube.com/watch?v=MRnE4JYk7Kg It is a fairly simple thing. Might help.
Old 09-24-2015, 10:27 AM
