Windshield washer runs dry in 1/2 pint!
I know the windshield washer capacity is over 2 gallons, but mine "runs dry" after about 1/2 pint from full. Works perfectly as long as I keep topping it up!
How easy is it to get to the reservoir and see if the feed pipe is too short or buckled, etc.?
Any suggestions, please!
1982 911SC Wine Red Metallic
OMG I love this car!
Old 08-29-2015, 02:19 PM
'82 SC TL
canamfan's Avatar
Left front wheel well (in front of wheel), very easy to check, screw on/off cap w/lines at bottle, and you're right it is a big reservoir.
76'S 1st Porsche white/can/can early rebuild (boo)
'84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1)
'87 Carrera cpe white/blue short flirt
'89 Anniv. sil/linen very pretty miss her
'88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Old 08-29-2015, 03:31 PM
'82 SC TL
canamfan's Avatar
1978-1983 brief schematic w/out headlight washer syst.
and with headlight washer syst. (this pic. also has newer nozzles fr. approx. 84-86 syst.)
Old 08-29-2015, 03:38 PM
This is curious! As shown, the pump sucks water through 2b, and forces it to the windshield nozzles via 2c. But 2b terminates at the TOP of the reservoir, at the left nipple on 32!! It is the CENTER nipple that connects to the suction pipe 2 and filter 3 in my car.
The long tube (above) is 2b, which goes to the left nipple and cannot get water unless the level is up to 32, and 2g is to center nipple and on to 2 and 3.
So it seems the drawing and my car are wrong! It should be that water from the reservoir is drawn up 2 through the center nipple on 32, to 2b, and the pump forces it to the nozzles via 2c.
(drain tube 2g should just return into the TOP of reservoir, via LEFT nipple, and overflow tube 2a is OK connected to the RIGHT nipple)
If I am right and the drawing is wrong, all I need to do is reverse the pipes at 32 going to the left and center nipples.
This I did, and now everything works fine!! This is crazy - either the drawing is wrong or they changed part 32 , which I doubt!
Old 08-30-2015, 11:35 AM
