Busted stud on fuel tank?
Hey gang, recently I was having trouble with my fuel sending unit, all is goo now; but I think one of the studs holding the sending unit in place is busted off. Take a look and tell me what you think. I dont think I have any fuel/vapour leaks nice I used gasket sealer when I put it back together and even using 4 out of 5 studs it seams to be pretty snug.
What would YOU do to fix this? ![]() ALSO, as you can see I do not have the metal cover that protects the hardware. Do you know where I can get my hands on one? Something like this I presume:
Extremely Yellow ’74 Targa 2.7 L - aka WIFE’S BANE |
Platinum Member
Normally, it's just a dry rubber gasket.
Part number is 477919133 for $5. There is so much friction from the other 4 bolts, that even with all 5 nuts off, it can be hard to lift and remove the sender. My guess is you'll be fine with 4 bolts and the RTV. Do you know how to use the part PET catalog? The gold cover is 90120127530 $12 here Search SiteSearch 90120127530 - ECS Tuning
1986 Bosch Icon Wipers coupe. |
1989 911 Carrera Cab 25th Anniversary Edition Euro Pre-Muffler, SW Chip There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad" |
Howzabout a barrrel nut?
This same thing happened to Cashman and Porboynz suggested using a barrel nut. This might work for me, can anyone tell me what exactly to buy? I know the nut is 8mm. I don't know much else about the broken stud or the name/size of barrel nut required:
Reminds me of the oil drain plate studs on a VW beetle.
When they break, they usually buy a step-up stud that is threaded into the wallowed out hole. Check this link from the Samba website: TheSamba.com :: View topic - Oil Strainer Step Stud Question
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
I already posted a $12 link for the gold cover
Help finding a barrel nut?
Well I've determined that it is an M5 thread from the gas tank. Now if I can just figure out where to get the barrel nut, I'd be all set.
I might try my hand in making my own protective cover. If that doesn't work then I'll purchase one. Thanks guys.
