1969 911T Engine Compartment Wiring Questions
Hello all. Finishing the restoration of my engine compartment and needed a little help with some wiring. Can anyone comment on the following? Sorry in advance for some of the pics/lighting. Here is the electric panel and alternator set-up for reference:
![]() ![]() 1.) Red wire (from Starter motor terminal 50). Does this go to Alternator B+ terminal or the B+ terminal on the engine compartment electric panel? Wire is long enough to reach panel and that seems like the natural fit. (wiring diagrams seem to point to both as options) ![]() 2.) Red w/longitundal white stripe (from Alternator B+) Confirming that this goes to electric panel B+? Seems like a natural fit as the 3-pin that is attached ends up at the Voltage regulator nearby (red/black/brown) ![]() 2a.) Alternator harness (near voltage regulator 3-pin red/black/brown) has a blue wire with male pin connector. Any idea what this is or where it goes? ![]() 3.) Metal ground + Blue/Ylw stripe (from Perma-Tune). Wire goes to Coil term 15. Where did the factory ground this? Coil bracket stud? ![]() 4.) Metal ground + Black (from Permatune). Wire goes to Distributor term 1. Where did the factory ground this? Engine block? ![]() 5.) Black/Prpl stripe (from firewall 4-pin connector). My notes say this goes to Distributor terminal 1 (like above) but I only have one male connector on my distributor. how do both of these - the black and black/purple attach? ![]() 6.) A previous owner attached a 10-12 gauge ground strap to the engine oil breather cover bolt (1 of the 4) any idea what that might be? ![]() Thanks! Kevin Sent from my iPad using Tapatalk |
ROW '78 911 Targa
Answers are in red
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 06-02-2014 at 11:26 PM.. |
ROW '78 911 Targa
For the dizzy wiring you need one of these:
Kevin,
Has your Tacho been upgraded? I see that you have the Intermediate unit fitted to your panel (small metal can) which drives or converts the CDI output to something that your Tacho can read. I'm on the iPad at the moment so can't post photos sorry. But it has a three wires brown(earth) blue/yellow ( A on coil) and one from the CDI can't remember the color sorry. I can check tomorrow. I'm assuming the purmatune is the same as the CDI but considering your notes the purmatune may pick up off the points. My 69t has the Black/purple hooked from the loom to the Intermediate unit. If you search for or have SL35 it shows the hook up of the Intermediate unit.
Classic 1969 911T |
Where you have the earth from the coil, move the braided line to the other coil clamp away from the fan!
Classic 1969 911T |
Rennch on YouTube
Dennis...as always, full of knowledge. Thanks for the awesome answer helping us folks years later.
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
