kevykev213
White smoke 3.2 engine
I was driving my porsche 911 3.2 liter out of no where I seen clouds of white smoke. Could someone tell what happened
Old 09-05-2015, 07:07 AM
word's Avatar
What were you doing when this occured? Accelerating? Decelerating? Any other accompanying symptoms or sounds? Is it doing this all the time now? Have you been able to replicate it? How many miles on the engine?
Old 09-05-2015, 07:12 AM
kevykev213
Just happened last nite I don't
drive it alot took it the carwash driving back home look back look like it was a fire of white smoke, pulled over and got it towed home
Old 09-05-2015, 07:26 AM
Brew Master
cabmandone's Avatar
My guess is you got some things washed onto the HE's that are now burning off. I've never taken my car to a car wash for fear I'd get water in the HE's. What did the smoke smell like? Where was it coming from? A little more info would go a long way here.
Old 09-05-2015, 08:36 AM
kevykev213
I put a quart and a half of oil it was on the low and then coming back seen all the smoke pulled over and had it towed home
Old 09-05-2015, 08:45 AM
Brew Master
cabmandone's Avatar
Again, did it smell like oil? Did you go through a drive through car wash that sprays the undercarriage? And did you check to make sure you didn't overfill the oil when you added 1.5 quarts. These cars don't like to be overfilled. Where was the oil on the dipstick with the engine running? I and many others from what I've found run these at the half way point. My guess is you got some oil on the Heat exchangers and it was burning off.
Old 09-05-2015, 08:48 AM
Sounds like a classic oil overfill to me. Kev, there are many, many threads about checking the oil level here on PP, but the key is to do it only when the oil is warm and with the engine at a normal idle speed. Many of us have better results keeping the oil level in the lower part of the OK range on the dipstick.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 09-05-2015, 08:52 AM
patz's Avatar
Sounds like you overfilled and sucked it up into the intake. Did you check oil on the dipstick on level ground, engine running and the engine warm, thermostat fully open?
Oil should be at just below the halfway mark on the stick.
I will use a FAF when I am dying of thirst
Old 09-05-2015, 08:53 AM
kevykev213
Yes it was min so I added a quart and a half
Old 09-05-2015, 09:01 AM
How do the brakes feel ?
A...
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 09-05-2015, 09:22 AM
kevykev213
Brakes are ok
Old 09-05-2015, 09:37 AM
patz's Avatar
And what was the reading after you added the oil?
biopsea's Avatar
very easy to overfill. keep mine at 1/4. plenty of oil. and heard that the difference between min and max is a quart or maybe even a bit less.
Toby
____________________
'77 Carrera 3.0
'07 C2S
Old 09-05-2015, 09:59 AM
180 degrees moves the oil from the bottom mark to the top mark, just like adding 2. Quarts of oil. That's why spec on the dipstick is warm, level and idle.
Bruce
Old 09-05-2015, 10:46 AM
kevykev213
It's alot better since I drained some oil. Thanks to everybody who had some feedback
Old 09-05-2015, 12:31 PM
69-912-swt's Avatar
I only add oil 1/2 quart of oil at a time. The hotter the motor is, the higher the oil level is. I try to keep my oil level at 1/2 level which when the gauge stops bouncing at traffic lights. Usally only needs 1/2 quart of oil to get the needle back to bouncing. Any higher oil levels seems to just burn off faster to get back to 1/2 level !!
Bill Kent
https://www.facebook.com/#!/NoSweatPhotography
1987 Carrera Targa
1969 912 SWT #0053
Old 09-05-2015, 01:12 PM
Troll Hunter
Adding oil is easy. Draining 'some' is a challenge.
Good for you.
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 09-05-2015, 03:09 PM
