crashr's Avatar
Question Help with Putting SC Flares on my 75 911S Targa
If I purchase some 911SC Flares for the rear fenders of my car... does the body shop have to cut into my old fender to mount them or do they mount on without cutting? Also what is the typical cost to put fenders on the rear of a car?
Any help would be greatly appreciated.
1975 Widebody 911 3.2 Euro
Old 11-19-2002, 09:08 AM
Ray 911s's Avatar
Photos of added SC flares to my 77 are poted here:
http://members.rennlist.com/ray911s/Bodybuild.htm
Old 11-19-2002, 09:19 AM
Somewhere in the Midwest
MotoSook's Avatar
Ray, I live in Illinois and have a 911S w/o the flares. I would like to one day do this to my car. Is the shop you used local? I'm in The Naperville area also.
Old 11-19-2002, 09:51 AM
Ray 911s's Avatar
Souk,
I used the same shop that Jack O. used for Black Beauty. You can contact Mark Carr at www.carrmotorcoach.com, (217) 826-6426. He is located in Marshall, IL. I called him after seeing that Jack bought his car from Mark and had him do the flares and paint. Photos of Mark's work-in-progress on Black Beauty are on Jack's Rennlist web page, and mine are in the link in the above post.
Old 11-19-2002, 10:31 AM
crashr's Avatar
I was just wondering.. Aprox. how much will this run me. Can anyone give me a breif breakdown.
Old 11-19-2002, 01:13 PM
Senior Member
Superman's Avatar
It takes a lot of work/time. you grind until you get shiny metal, particularly on the car's existing body (don't watch). You attach the new flares with huge vise grips. tak weld. adjust if necessary. REweld. grind. Weld. grind. weld. cut off the old flares. grind. sand. mud. sand. mud. sand. sand. sand. paint. sand. paint. sand. paint....
Mocha 1978 911SC. "Coco"
Old 11-19-2002, 01:33 PM
Rouxzy's Avatar
Had mine done by a vintage restorer. Used some type of melted metal to fill in rather than bondo or fiberglass after welding on the extensions. Even did under the fender so you cannot even tell that they were added on. Nice nice job.
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 11-19-2002, 02:03 PM
74911s's Avatar
here in socal i have quotes from $900-2000 to weld the rear flares and deliver primered ready for paint. this does not include the cost of flares.
Jim
R Gruppe Member once upon a time when you could run generators in Cambria to fix the cars and hit 150+ mph on the fun run
"Alles ist gut" 2011 997 GTS
"Orange Pepper Wagon" 2009 Cayenne GTS
Old 11-19-2002, 02:08 PM
Paul Valcourt's Avatar
I just had this done to mine at a local Body shop. Your wheel opening will have to be cut back from the lip about 5", this will be dertermined by the fit of the new flair to the existing panel. I purchased new factory parts for this update and the cost of the parts were almost as much as the labour to install. If I were to do it again I would look for some clean rust free parts from the southern states, this will save you quite a bit of money. Check with others on this board and someone should be able to direct you to someone who has these parts. Used SC flares cut back about 9-12" from the wheel opening at the top and 7-9" near the bottom will leave plenty of metal to work with for re-installation on your car. You will also need the SC metal bolt on rocker panel (your rubber insert will fit if the part does not come with it) and the SC metal bumper extentions. You could probably find a good body shop in Ontario to do the installation for under $1000cdn plus painting.
75 targa 2.7
Lean and green
Old 11-20-2002, 12:17 PM
