PPI results -- deal breaker?
Hi all you mechanics. I received results on a '88 911 with around 115,000 miles. There are a few mechanical issues the ppi uncovered that I could use some help evaluating.
1. Partially crushed oil lines with ~10-15% reduced flow.
2. Brake lines are original
3. Fuel return hose in front of the motor is badly cracked.
4. The fuel distribution line was repaired with generic hose rather than replaced with a Porsche part.
Overall, the car presents and drives excellent. Emissions are good and leak down is 3-5% across all six.
The car is priced fairly prior to the discovery of these issues. Any idea what it would cost to repair these items? Are they a deal breaker? Thanks very much.
Old 09-04-2015, 04:33 PM
Reiver
Reiver's Avatar
Wouldn't be an issue with me.
Go thru the brakes etc, replace whatever hoses and go.
That reduced oil flow from the front radiator may be nothing at all as most have a ding or two in their lines. I've a couple and my car runs cool in Az heat.
The thing one only finds out from owning is oil use....miles per quart that can indicate wear in guides etc.
De Oppresso Liber
Strength and Honor 5th Legion
Old 09-04-2015, 04:39 PM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
I agree with Reiver - nothing there that would cause me major concern. The oil lines are the only items that might be significant costs for the average do-it-yourelf'er.
Go for it and be sure to post pics - and welcome aboard!
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 09-04-2015, 04:50 PM
NathanR's Avatar
Send a message via Yahoo to NathanR
Buy it!!
Then fix all that stuff yourself. Start w/fuel line. I just did mine. Took a few hours to remove all the stuff in the way, then it was relatively not difficult
87 Carrera Coupe
Black on Black, H4 Headlights, Nurburgring Sticker
Old 09-04-2015, 04:53 PM
To me, none of that is a deal-breaker on a almost 30-year-old car. In fact, it's expected. I generally go through and replace all the "consumable" hoses and fluids on a used vehicle when I buy it.
Old 09-04-2015, 04:58 PM
gearhead
I wouldn't hesitate to buy that car. That's nothing on a 25 year old car. If I was selling it I wouldn't negotiate much with you over those things. If you passed I would add them to my ad and wait for another buyer. Sorry, but it is a seller's market.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 09-04-2015, 05:00 PM
Cars and Cappuccino
tdw28210's Avatar
Nothing too scary.
Leakdowns are good.
Replaced a short fuel line to filter this week. E85 compatible (good stuff) with cover and crimped end - $10.00. Whole shooting match is around $450.00 for everything.
Oil lines can be fixed with a threaded end and some air pressure. Search here.
Also search here for post by Len as another source of fuel lines.
Use these issues as leverage to lower the price...ask for 2.5k off. Labor is the expensive part if you don't do these yourself.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 09-04-2015, 05:04 PM
porsche boy's Avatar
If the leak down was an issue then may be a problem. The other issues and weekend projects. Go for it.
Old 09-04-2015, 05:17 PM
beren's Avatar
Go for it - i have an '88 Carerra. Fuel lines should all be replaced if they are original. I also have a partially crushed oil line at the passenger wheel well, but things still seem ok even in very hot summer driving in Philly area.
Expect to pay about $3K (USD) for parts and labor if you are going to have someone replace all the fuel lines with new.
Old 09-04-2015, 06:28 PM
patz's Avatar
Have the owner fix it or get a credit.
I will use a FAF when I am dying of thirst
Old 09-04-2015, 08:01 PM
