-   -   Little, Tiny Spring. (http://forums.pelicanparts.com/porsche-911-technical-forum/881904-little-tiny-spring.html)
86 911 Targa 09-05-2015 12:32 PM
http://forums.pelicanparts.com/uploa...1441481466.jpg
I found this little guy under the car, adjacent to the pass side rear tire.
Where does it go?
Thanks in advance,
Gerry
patz 09-05-2015 12:41 PM
Gas door?
john walker's workshop 09-05-2015 12:53 PM
Alien spaceship blue ice discharge flap.
sugarwood 09-05-2015 01:19 PM
Hold me closer tiny spring
Count the headlights on the highway
patz 09-05-2015 02:16 PM
There is the spring.
http://forums.pelicanparts.com/uploa...1441487792.jpg
sugarwood 09-05-2015 04:22 PM
The fuel door spring has more coils and is missing the loop on one end.
Unless they varied by year.
86 911 Targa 09-05-2015 05:02 PM
Spring.
Originally Posted by patz (Post 8782550)
http://forums.pelicanparts.com/uploa...1441497719.jpg
Good try, but the spring is on the gas cap.
Thanks,
Gerry
dad911 09-05-2015 05:07 PM
C'mon guys, JW ID'd it in the 3rd post.
tirwin 09-05-2015 05:16 PM
Ha!
McLaren-TAG 09-05-2015 06:27 PM
I'd start by giving the car a once over twice. Looking for things that should be springy but aren't any longer. After an hour if I can't find anything broken, put it in a drawer just in case you figure out two years from now where it went.
billybek 09-05-2015 07:39 PM
Heat box?
DRACO A5OG 09-05-2015 08:21 PM
I really do not think it belongs on our 3.2's Dr Gerry.
86 911 Targa 09-05-2015 08:37 PM
Spring.
Originally Posted by billybek (Post 8782868)
Heat box?
I did check the heat box, and that spring is still attached.
Thanks,
Gerry
steely 09-05-2015 10:41 PM
It doesn't look like it's from the brakes or the throttle body.
Did you happen to walk by the car with any wire strippers or garden clippers? I was wondering if it fell off of some sort of hand tool or even a small clamp you may have had in the garage.
brighton911 09-06-2015 03:50 AM
Gerry, I do not recognize that spring as part of our 86's either. Maybe a playful neighbour is messing with you.
86 911 Targa 09-06-2015 09:18 AM
Spring.
Thanks to all for you constructive comments.
The car has been stationary for about three weeks during an A/C
re-install.
So perhaps this little guy showed up during the work from
another source.
As stated by several members, I don't think it came off the car.
I'll check one more time.
Best,
Gerry
