MSD rev limiting
Hello Everyone
I installed the MSD 6425 what rev limiting should I put in it ? Thank you ! |
My 81SC has a 6,400 RPM red line. I set mine at 6,500 with a pill on my older MSD 6AL. You probably have a dial. Others will have better data once they know which car. |
Sorry indeed You all miss some information
I have 1970 911T |
Thanks for that bit of info; I failed to see that in your original post,.. :) :) Set the rev limiter for 6500 RPM as that's the safe limit for cast pistons. You are well past the power peaks at that RPM, anyway. |
my redline is 6700, i set mine to 6500.
930 |
| All times are GMT -8. The time now is 05:44 PM. |
