-   -   BBS 16x7 RS157 and 16x8.5 RS131 Fiment (http://forums.pelicanparts.com/porsche-911-technical-forum/881963-bbs-16x7-rs157-16x8-5-rs131-fiment.html)
x19m3 09-05-2015 09:58 PM
Hello everybody,
I'm looking to buy a set of BBS RS for my 87 911 Carrera. I found a Pelican member that has a set of two 16x7 BBS RS157 ET49 and two 16x8.5 RS131 ET56. I would like to know if this rims will fit on my 87 Carrera without any problem and if they will look ok with this offset.
I know in here there are very smart people that can answer on my question.
Thank you in advance.
Arne2 09-05-2015 10:25 PM
Need big spacers. Correct offset for 7" is 23, so you'd need 25mm spacers on front. For rear8.5" you want 10-12mm, so probably 40-45mm rear spacers would be necessary.
Bleedsblue 09-06-2015 12:45 PM
You've found some 964 offset wheels, OP.
Arne's right, but I would never run spacers that big--not to mention, you'd be missing out entirely on the great low offset lips of wheels that fit the car sans spacers.
