Noisy Engine
Last year I used Brad Penn 20-W50 synthetic oil and the year before VR1 synthetic
both worked well but with oil leaks.
The engine is a 2.4T and not sure if it has ever been opened as I have no records of it's past and it likely needs a rebuild but I'm not ready for that yet.
Anyway this spring I changed the oil with VR1 racing 20-W50 conventional to try and
stay away from the synthetic oil to see if it would clear up some of the leak issues but the engine seems to be noisier.
Any thoughts on this would be appreciated.
Mike
Old 04-22-2016, 07:20 AM
Brap
tmaull's Avatar
How long since you adjusted the valves? What kind of noise is it?
1980 911SC Coupe 3.4
1995 Miata
2005 Tacoma
2009 Street Triple
Old 04-22-2016, 07:21 AM
Hi Tmaull thanks for the reply Just adjusted about 1000 miles ago and sounds like a dry bearing sound from chain case area or #8 bearing area?
Old 04-22-2016, 09:00 AM
The nose bearing won't be dry, generally there is no wear factor for it because is under case oil pressure. If you were dry, you would already lost bearings at 1,4,and 5 rods.
Check your chain tensioner so.
Bruce
Old 04-22-2016, 10:31 AM
Thanks Bruce I think I found some thing else. Just noticed some wearing on the bottom inside of the fan shroud so I loosened the nut a bit to take a little tension off the belt
And it seems smooth again. Cross fingers that that was the problem.
Old 04-22-2016, 03:53 PM
If your leaks are slight try a couple of cans of ATP-AT-205 re-seal from Amazon. Been around forever and has great reviews. My 85 does not leak!! And runs like a top with 150,000 on the clock.
Old 04-22-2016, 04:14 PM
LakeCleElum's Avatar
Sounds like you have your noise issue solved. Hopefully.
Just from 20+ years with a 2.4:
Being a mag case engine, the main sign of trouble is low oil pressure......When pressure drops near zero at idle when warm is a wake-up call.....
.For me, I was was able to prolong things several years by addressing oil temps.....Keeping the cylinder fins clean and adding some type of oil cooler can put off a rebuild for many years.......G'luck...
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 04-22-2016, 09:05 PM
