great project, I like everything your doing to your car, think it will look stunning when done
1988 Toyota 4Runner Gen1 1989 Porsche 930 1990 Porsche 964 1994 Toyota 4Runner Gen 2 |
This is exactly why I like it
Lots of people think they have attention to detail but very few actually do, you sir in my eyes have it!
I have a Carrera 3.0, which some day will be put back to its original guise, oak green. You've just showed me the perfect upholstery. Thanks.
Absolutely fabulous execution, and attention to detail.
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Banned but not out, yet..
The seating alone is a work of art. Great project and great execution (but not in a lethal sense).
An air cooled refrigerator. ‘Mein Teil’ |
Thanks for all the compliments, but the real skill is in the hands of Greg and Glenn at Awesome Upholstery. It has been a work in progress and the lads really have worked hard to make my vision a reality, and occasionally given my ideas a sanity check.
They truly are masters of their art... |
Wow amazing work!!
Beautiful project you've got going, can't wait to see how it comes together! What model Recaros are those?
1978 911SC |
They are Recaro Rallye 3's. Apparently quite rare, so if you see anymore anywhere, I'll have them. recaro rallye 3 seats |
More of Greg's craftsmanship has been completed...
The only other significant thing was most of the inside has been soundproofed prior to putting in extra soundproofing at significant points.
![]() ![]() ![]() So its all going well, and the next stage will be headlining, carpets, rear-seat-delete, audio and fitting of the seats.... Quite a lot really... |
Eng-o-neer
The method of laying down a single layer of CLD all over the panels is old-fashioned. You can achieve greater sound deadening for the same weight, or equal deadening for less weight by employing three layers of materials:
Interior sound deadening, noise reduction, and thermal insulation Apparently the difference is quite dramatic, but I can't comment personally (yet). Did you pull up the old half-ovals of sound deadening (underneath which is a neat hexagonal pattern)? |
Im not sure where you mean? The black layer is only the first... |
Eng-o-neer
Ah, understood. In that case, I think you would get away with 50% coverage instead of 100% coverage and obtain the same performance.
100% coverage of CLD has no downside vs 50%, but it would add more weight for no great reason. In any event, please document the next bit! I'm still in the middle of this job with my car, and I'm very interested to see how to get everything in and still have it be removable, get into nooks and crannies, how many layers provide diminishing returns in the "problem" ares of the engine and wheel well, etc... |
The ratio of surface area of CLD to panel area isn't fixed. It depends on the mass of the material, the stiffness of the panel and a whole host of other factors. Bottom line, since nobody is actually testing any of this on a 911 shell, it's all just an educated guess. Or just a wild-ass guess...
JR |
More seat updates. Firstly they were put back in the car and I sat in the driving position as various pieces of foam were put under thighs and another piece scooped out from under my ass:
![]() Greg then shaped the foam perfectly and sent me this picture today of the nearly finished seats: ![]() The blood pressure cuff valves lead to the lumbar support. The seats just need some press studs on the sides to tension the leather sides. |
Thread Tools | |
Rate This Thread | |
