does Pelican or Porsche sell these fuel lines
![]() I need the lines, clamps and the Tee. I suspect the lines and clamps are easily had. Not so sure about the Tee. Thanks, Chris 1973 911 E |
Tired Member
888-280-7799
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
How does one connect the two top lines #25? Do they come with the hard lines attached?
Thanks, Chris 73 911 E |
9mm from tank strainer to body: 13 inches
7mm from tank drain banjo to body: 14 inches 9mm from body to fuel pump: 30 inches 7mm from body to tee: 22 1/2 inches 7mm from fuel pump to tee: 7 inches 7mm from tee to hard line at engine: 6 1/2 inches 7mm from fuel pump to hard line at eng. 14 inches Hoses bought here: 7mm from our host 9MM www dot auto haus az dot com part number N203761 Fuel Hose/Line; Fuel Rated; Braided; 9mm ID; Bulk Clamps: [url]http://www.clipsandfasteners.com. Look under clamps, hose and tubing, fuel injection hose clamps type G. Here's the best thread on this subject and is where I got a lot of info. If you do not care about how the the hard lines are connected to the old braided fule lines then cut the fasteners off using a dremel.. Braided Fuel Hose for a 72T MFI
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 05-02-2010 at 08:38 AM.. |
Chris, I don't think the hard line is available anymore. I could be wrong. You can get straight hardline, bend and shape it as needed, then with a special tool you can make a nice smooth barb on the ends then use the metric fuel line clamps to secure the lines.
Mark Jung Bend, OR MFI Werks.com |
Sean 1982 SC D-Stock #372 NASA GTS2 1971T restoration in progress, read about it here: http://911restorationmadness.blogspot.com/ |
someone had posted a picture of what I intend to do at this point. Someone please correct me if I should not do it this way.
Buy the EOM lines from Pelican in the appropriate metric sizes and lengths. Connect everything with the appropriate clamps from Pelican. This includes using the clamps (screw type) for connecting to the hard lines and Tee fittings. Is this the right way to go? thanks, Chris 73 911 e |
The 9mm hose on pelican is not the right hose for your application if you have MFI. I cut off all the fasteners and used all the parts I posted above. It's up to as to what you want to do. If this is a car you want kept org. then don't follow what I did or what is shown in the thread I attached, but it works great and looks very clean. One other thing, the fuel lines in your pic don't look all that bad, but looks can be deceiving. The lines that attached to the fuel pump on my car were frayed to all hell.
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 05-03-2010 at 06:16 AM.. |
This is what I am referring to.
Will this work with MFI?
It's what I did and it works great IMO.
72 911 Although it is done at the moment, it will never be finished. |
Holy cow. I ordered the above setup from Pelican.....$90....for fuel lines and a couple clamps.
oh well. should last another 30+ years Chris 73 911 E |
![]() EVERYTHING out of Germany is more expensive now. Perhaps w the Euro falling we will get a break soon. Len
![]() Good info, bump to top.
![]() I have in stock all the correct hose, fittings, crimp sleeves and Norma clamps; and now have the hardline to make replacements for MFI vehicles. Please email me if needed. len at autosportengineering dot com
