Anyone know hoe to fix a sideview mirror?
Car:85 carrera w/ stock "flag" power mirrors
problem: driver's side mirror is rotating freely on its' base and will not stay put. I frequently fold the driver's mirror after parking in my garage(it's tight). I must have worn or broken something but I can't tell what. I can now wiggle it right up and off the base as far as the wires will allow. What I see is what I would call a "cam riser" on the base with a threaded shaft in the middle. Anyone have any idea how to fix it? |
You need to take the mirror off the door;
1. Remove the glass 2. Remove the motor assembly (3 bolts) 3. Disconnect the harness pins from the connector, you will need a snap-on tool for this. MAKE A NOTE where the pins are located in the connector. 4. Loosen, but do not remove the allen bolt in the mirror base until you can remove the mirror from the door. 5. Pull the mirror carefully away, feeding the wiring through. 6. With the mirror on the bench, unscrew the bi-hex bolt that holds the mirror to the base. Note there is a spring in there. 7. Check the condition of the two plastic bushes at either end of the spring, if damaged; replace. You will have to get them from a Porsche dealer. 8. Loctite and refit the screw. 9. Put is all back together and check the operation of the motor and heating element. |
I understand everything except how do I remove the glass?
The fastener resembles the male portion of the door panel attachment. (Crude description )
That portion is on the glass. There is a female socket in the mirror assembly. Stop by an auto glass shop and pick one of their seal installing tools. Fiber gizmo, with blades and both ends. Nice for prying delicate stuff. Interior and glass. Good Luck ------------------ Cary Kutter 77 Euro Carrera w/3.2 74 914 2.0 ( base model ) PCA Region - Big Sky |
