have you ever heard oil flow to the cooler?
After changing my oil and driving it, I heard oil flowing from the engine to the oil cooler. I have never heard this before. I guess some air got into the line and was eventually flushed out because I didn't hear the sound again.
Has anyone else ever heard this?
Stopped racing and became a drummer |
Senior Member
I have heard it on a hot day after pushing the car pretty hard. Seemed to go away after I drove easy for awhile. Haven't heard it since i rebuilt the engine though.
78 Euro 911sc Targa 03 Hayden SCWDP |
I use to hear it all the time, use to because a) I don't remember the last time it was over 50 degrees and b) engine is no longer in the car.
Is hearing this a '78 thing?
Rob Fix '78 3.6L SC Targa Eiche Gruen Metallisch |
Are you sure you are not hearing it draining into the oil tank?
It is common to hear that. Like the sound of running water! |
NASA instructor
I never heard before I upgraded my cooler to a B&B unit, Now I hear it when the temp gets to about 180 degrees. Just like running water.
Matt Rich 1999 Porsche 911 Zeniith Blue 1999 BMW 540i 2011 BMW 535i |
I hear it at idle in the garage (ie a quiet place) when the engine is hot.
I have only heard it in '79 Turbo when warmed-up and at idle in a quite place. Sounds like a gurgling stream. It is pretty distictive from the rocker area that the hoses run through.
DL Geer '79 SC Targa '79 Turbo Coupe |
yes! it sounds like running water.
I can hear it too, particularly after a stretch on the motorway. Kind of soothing, actually. No reason to worry, I take it?
Axel. 1973.5 911T Targa (RS upgraded engine) 1996 VW Passat Wagon (yawn...) |
So that's what that noise is!! PHEW!! I figured it had to be something like that.
The first time I heard this was after I put the motor back into the car and ran it (I bought my car with a non-running motor). My first thought was, "OH *****!! What the heck is leaking?" And then when I looked under the car and saw nothing, I was a bit puzzled. -Dave |
