Madsimilius
Madsimilius's Avatar
Can anybody help me identify these connecting rods? RSR?
I´ve been curious what my bottom end was for a while, so i bought an inspection camera and stuck it in trough the oil tubes in the lower camhousing.
I´m curious if they might be the same as in the 3.0 rs and rsr.
I found the number 1130 and a last letter that looked like a worn out R or F
I've only found the the number 1130R on 3.0 rs and rsr rods when searching through pictures on the web.
I also found out my engine has ARP rod bolts which was good news
here's some pictures.
911sc, 3.1, ported 40mm, cams and titanium retainers, carrera 3,2 intake, ms3x, k27/k29, full exhaust,
Old 09-09-2015, 01:25 PM
Madsimilius
Does anyone know if any other porsche rods has the number 1130R ?
If say the 911 sc rods don't have the number 1130R on them i can rule them out.
When i got my car it didnt have a rev limiter and it has been over 8000 rpms several times :/
now i´ve sett a rev limiter to 7500rpm
Old 09-10-2015, 11:59 AM
Uncertifiable!!!
Uwon's Avatar
You may want to post in the 911 engine building forum for an answer. Great brain trust there.
Good luck.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 09-10-2015, 10:20 PM
Hi,
I hope, for your sake, that your crank has been cross-drilled, the case modified and the center main bearing grooved for oiling. With those crankshafts, the bottom end isn't safe unless you have a GT-3 crank and aftermarket rods.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-10-2015, 10:34 PM
Madsimilius
Unfortunatly i don't know who built it, or who owned the car when this was done.
If i had known i could have just asked.
I bought the car from a seller in Norway who had imported the car from USA, Callifornia i think, in 2011.
If these are 3.0 rs/rsr rods i won't need aftermarket rods as the rsr is buit for over 8000rpm or?
If the shaft hasn't been crossdrilled, about how much would it cost getting it done?
If i can find any good info on this, my cousine is a machinist and is always wiling to help me out.
As much as i love the thought of having a bulletproff short stroke high rpm engine, for a high power turbo engine, is a long stroke engine preferable? I would think the short stroke heads would get much warmer ?
A lot of questions here :P
Old 09-15-2015, 11:27 AM
Madsimilius
Originally Posted by Steve@Rennsport View Post
Hi,
Is it possible to see on the crank shaft if it has been cross drilled. The plug ? where would it sitt and how would it look?
In that case i'll try with the camera, and if i can't find out if it has been cross drilled, i guess i'll have to dismantle the engine.
Old 09-16-2015, 02:27 PM
Fleabit peanut monkey
Bob Kontak's Avatar
The crankshaft main bearings or journals are not view-able.
I called my pal last night that has racing Porsches (GT3 RS and a Cup car) and asked him about a stroker vs spinner crank and he did not know regarding turbo charged.
I then asked about the GT3 crank Steve mentioned and he said "Yes, I know this is performed on higher HP retro-fits"
You have risk if not handled correctly based on the advice from a professional. I would listen to Steve.
Another option is to back off on the boost and live with some risk?
1981 911SC Targa
Old 09-16-2015, 03:26 PM
Madsimilius
Found some old pictures of the car from the add when i bought it ! Under the lisence plates it says NOIR TECH MOTORSPORTS. I'm gonna give them a call today and ask if they remember building this car.
I found some info on the workshop here on pelican , and it seems the main guy ? Tony Miller has quit.
I get that i can't see the journals or bearings, but i was hoping i'd be able to see if it had been drilled from where the hole entered and was plugged?
Gt3 crank would be awesome! i guess it wouldn't be spinning as free though due to the long stroke it has.
Thank you for the info and tipps guys
Old 09-17-2015, 03:31 AM
