RazorRacer's Avatar
have you ever heard oil flow to the cooler?
After changing my oil and driving it, I heard oil flowing from the engine to the oil cooler. I have never heard this before. I guess some air got into the line and was eventually flushed out because I didn't hear the sound again.
Has anyone else ever heard this?
Stopped racing and became a drummer
Old 11-19-2002, 07:45 PM
Senior Member
I have heard it on a hot day after pushing the car pretty hard. Seemed to go away after I drove easy for awhile. Haven't heard it since i rebuilt the engine though.
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 11-19-2002, 07:48 PM
rfix'n's Avatar
I use to hear it all the time, use to because a) I don't remember the last time it was over 50 degrees and b) engine is no longer in the car.
Is hearing this a '78 thing?
Rob Fix
'78 3.6L SC Targa
Eiche Gruen Metallisch
Old 11-20-2002, 08:55 AM
Are you sure you are not hearing it draining into the oil tank?
It is common to hear that. Like the sound of running water!
Old 11-20-2002, 09:05 AM
NASA instructor
bornrich's Avatar
I never heard before I upgraded my cooler to a B&B unit, Now I hear it when the temp gets to about 180 degrees. Just like running water.
Matt Rich
1999 Porsche 911 Zeniith Blue
1999 BMW 540i
2011 BMW 535i
Old 11-20-2002, 09:17 AM
nostatic's Avatar
I hear it at idle in the garage (ie a quiet place) when the engine is hot.
Old 11-20-2002, 09:20 AM
I have only heard it in '79 Turbo when warmed-up and at idle in a quite place. Sounds like a gurgling stream. It is pretty distictive from the rocker area that the hoses run through.
DL Geer
'79 SC Targa
'79 Turbo Coupe
Old 11-20-2002, 09:26 AM
RazorRacer's Avatar
yes! it sounds like running water.
Old 11-20-2002, 02:58 PM
I can hear it too, particularly after a stretch on the motorway. Kind of soothing, actually. No reason to worry, I take it?
Axel.
1973.5 911T Targa (RS upgraded engine)
1996 VW Passat Wagon (yawn...)
Old 11-20-2002, 10:05 PM
So that's what that noise is!! PHEW!! I figured it had to be something like that.
The first time I heard this was after I put the motor back into the car and ran it (I bought my car with a non-running motor). My first thought was, "OH *****!! What the heck is leaking?" And then when I looked under the car and saw nothing, I was a bit puzzled.
-Dave
Old 11-22-2002, 12:43 PM
