Disconnecting CIS Fuel Lines
Hi Guys, I'm removing my CIS to fix all my air leaks once and for all. I need to undo this fuel connector. I believe this is the return line.
Do I just put the correct wrench on the nut and undo it? Seems wierd there's nothing to counter hold. I don't want to break it.
Thanks for all your advice as always.
G.
Old 09-19-2015, 12:21 PM
#12 and #17 mm wrenches........
G.
Gary,
If my memory serves me right, I used a 12-mm and 17-mm wrenches to loosen this particular return line. Or an 11 and 17 combination (?). Form a V-set up with the wrenches and compress them together. Are you dropping the engine?
Tony
Old 09-19-2015, 02:10 PM
Hey Tony,
Welcome back I hope your trip was good!
There only seems to be one nut so I was thinking of counter holding the metal crimp on the other half of the hose with vice grips.
I'm not actually dropping the engine. I know this is *not* the recommended way to do it but I don't have the room to drop it unfortunately. My garage is too small.
It's back breaking and i've spent hours on this (I'm in no rush) but i'm about 3/4 of the way there. I just need to undo these fuel lines and undo the airbox support bolt and that nasty inside nut on the number 6 runner (I have lots of 1/4" swivels and flex adapters) and I should be able to lift the rest of the CIS up and out with just the 5 & 6 runner attached. Hopefully the engine breather hose won't be too much of a bear either ...
Old 09-19-2015, 03:03 PM
if u look close there is a machined area between the metal tube and the fitting on the rubber hose, thats where u put the 12mm
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 09-19-2015, 03:08 PM
Cool thanks so much Jason. I've not encountered a fitting like that before.
Old 09-19-2015, 03:36 PM
