No starting power
Guys, I have an 81sc that I just changed the fuel pump in. I now have no starting power? I have power to the pump and all lights but car will not crank. Any ideas?
Old 09-20-2015, 05:25 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Won't crank but does the starter (solenoid) click?
Battery charge may be tired.
1981 911SC Targa
Old 09-20-2015, 05:35 PM
patz's Avatar
if it clicks, whack the solenoid with a wrench or Bob's head.
I will use a FAF when I am dying of thirst
Old 09-20-2015, 05:38 PM
I put a charger on it for extra boost. The starter does not click
Old 09-20-2015, 05:43 PM
patz's Avatar
Something is loose.
Old 09-20-2015, 05:46 PM
Bob Kontak's Avatar
It can click but not spin without required amperage OR a poor connection (same result).
A better way to say it is the engine tries to turn but can't.
Edit: Oh Jeez, it's Mikey.
1981 911SC Targa
JOHN21BLACK's Avatar
Did you disconnect your battery when you change pump? Check your ground cable on battery.
Old 09-20-2015, 05:51 PM
I did check both terminals for good contact. I wonder if I should check power to starter?
Old 09-20-2015, 05:55 PM
The solenoid clicks, so it is "apparently" working but it still may be faulty. Get under the car and use a wide bladed screwdriver to jump the two large studs on the back of the solenoid--the one with the battery cable and the one with the braided wire that goes to the starter. If the starter runs when you jump those two terminals, the solenoid is the faulty part. If the starter still doesn't run, or runs slowly, then you have an issue either with the power to the terminal from the battery, loosened ground connections, or the starter itself is faulty.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-21-2015, 07:30 AM
Diss Member
Quicksilver's Avatar
Another little information gathering exercise is to turn on the headlights and see if the lights dim when you crank. That will tell you if the starter is able to pull the power. If it doesn't dim at all then the power isn't getting there. Think loose cable, bad connection, toasty solenoid, or even the starter brushes.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-21-2015, 07:54 AM
