LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
Originally Posted by Apothecarian View Post
R Martinez - did you encounter any figment issues with rear " 9 " ? Rolling of fender or rubbing ? What tire size on the 9. Thanks.
I've had no fitment issues swapping between the 16 x 7/8 set up and the 16 x 7/9 set up. Suspension/torsion bar set up is factory stock sizes.
7/9 set up uses Bridgestone Potenza RE 11 205/55R-16 Front + 245/45R-16 rear.
7/8 set up uses Continental ExtremeContact DW 205/55ZR-16 Front + 225/50ZR-16 rear.
Old 09-23-2015, 06:13 PM
Farrell's Avatar
These cars look great!
I can't wait to get my 16x8's painted.
However, will 225/45/16 and 245/45/16 work? Specifically, is there a reason no one is using 245's on the back and is a 45 too short of a side wall up front?
Old 10-09-2015, 05:46 PM
Fastest Hunk of Junk
I run 225/45 up front, and love it. Most don't like pinching a 245 on an 8. I would only do it with a very stiff sidewall, and even then it would underperform compared to a 9.
-Brent
Porscheless, sold '86 911 to buy a house
'84 Toyota Land Cruiser
'91 BMW M5
'10 Mini Justa (hers)
Old 10-11-2015, 11:01 PM
J-Mac's Avatar
My 75 with 7 and 8s. Turbo brakes, so spacers are on there, but don't know the sizes (PO installed). Front fenders rolled...
J Mac
Current - 75 911 Carrera #144, modified
Sold - 67 911T Coupe racecar, 87 911 Cabriolet, 85 911 Targa, 98 Boxster, 95 993 Coupe, 88 911 Cabriolet
Old 10-11-2015, 11:48 PM
TheSt|G's Avatar
People don't use 245s on the back because the selection is pretty terrible at this point.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 10-12-2015, 04:10 AM
Been here a while
my 83 with 16x7's and 8's
Old 10-12-2015, 04:21 AM
Mark N
Fuchs 7,8 x16 Michelin A/S 3 Pilots (205,225) 5mm spacers on rear, front lowered one turn, to give a slight rake, toe adjusted. Normally front sits a little higher but, trunk loaded with full tank for Rennsport Road trip.
Because it makes me Happy
Old 10-12-2015, 04:30 AM
Farrell's Avatar
Sweet, looking forward to getting my car back hopefully this week, so i can get my new 16x8s on there.
i was looking at the toyo r888 tires and thats where i was considering a 245/45/16 for the rear and 225/45/16 for the front. i saw many people running 225 50 up front and toyo has both sizes so i did not know if one was better etc?
I'm sure the 50 would be a little more cushy of a ride? sidewalls should be pretty stiff in the r888.
Old 10-12-2015, 04:44 AM
16x7 front 16X8 rear
Old 10-12-2015, 05:22 AM
I chose the 225/45 for (assumed) steering precision, additional lowering, and to give myself an easier time of lowering the front. I run them out back too, to shorten the gearing a bit (and because I have stock power at 5280 ft).
That set-up with R888s will definitely be fast, and look great. As Stig mentioned, the problem for most is that there is really only one street tire in 200 treadwear or higher in 245/45/16 (Bridgestone RE-11).
-Brent
'91 BMW M5
Old 10-12-2015, 08:30 AM
Porsche Crest 16" Fuchs 7" & 8"
Old 10-16-2015, 06:42 AM
"O"man(are we in trouble)
widgeon13's Avatar
Old 11-03-2015, 05:17 AM
TheSt|G's Avatar
Some recent shots of mine:
Old 11-03-2015, 09:31 AM
Mr. Merk's Avatar
Some amazing looking cars in this thread
1988 Venetian Blue Carrera Sunroof Coupe 3.2
2008 Basalt Black Carrera 4S Coupe 3.8
2008 Black Cayenne Turbo 4.8
www.instagram.com/patrickossenkop
Old 03-26-2018, 02:14 PM
I think this is 205 front, 225 rear.
Chris -
1975 911s "Outlaw Rat-Rod" - steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) - SW Chip, Fabspeed Headers & Exhaust, RetroAir A/C
2001 996 Turbo - ~42k miles
Old 03-26-2018, 02:48 PM
duc hunter -- are your fronts 951 offset 16x7 fuchs? They don't look to me like 911 offset 16x7 fuchs and I understand 951 offset 16x7 wheels look very similar to 911 offset 16x6 fuchs
Old 03-26-2018, 03:31 PM
7"/9" x 17" Fakes - street
7/8 x 16" Real Fuchs - Track
1979 SC
1986 Carrera 3.6 L+
Old 03-26-2018, 03:38 PM
They are the factory wheels that came on my 89 25th Aniversary Edition car. I do have spacers on them so they fill out the wheel wells better. That is the factory original finish too.
Chris -
Old 03-26-2018, 03:50 PM
they look great -- believe factory fronts on '89 carreras were 16x6
Old 03-26-2018, 03:51 PM
Air Cooled
Craig_D's Avatar
Yep, they do look good, but those look like 6/7x16.
Here are 7/8x16 on an SC (same as a Carrera look wise):
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
2012 Ducati Multistrada S, 1995 Ducati 900SS LWCR
'88 Honda Hawk GT, '77 Honda CB750K Cafe
Old 03-26-2018, 04:06 PM
