930 ATE 23mm Master Cylinder
Just got my ATE 23MM M/C today for my 930 brake upgrade. Does anyone know if it has to be bled of air bubbles and if so. How? I was just going to hook up and bleed brake lines with vacuum bleeder.
Any Ideas Bill V. the master guru of 930 brake upgrades
You could bench bleed it, but I recently did the same install and didn't do so. Works great with the regular bleeding procedure.
John not that I think it makes any difference but just for reference is it boosted or non boosted?
What year is the install?
PJ 78 911sc Targa 70 911T |
I ordered boosted per part number 930.355.011.03. 1984
930 brake caliper modification (rear)
Sending the back halves of 930 calipers tomorrow to Rebel Racing to be modified.
Just curious...what are you having modified on the 930 calipers and why?
For the 930 rear calipers to bolt on to 1984 banana arms the holes are re-drilled. Hole spacing is 3.5in. On calipers. On arm it is 3.0in. Only way around this modification is to have a 930 torsion arm tunnel welded on and then your able to have 930 turbo banana arms. To much work. Easier to have modified calipers.
930 rear caliper modification
This is how it looks after modification.
