All the cars are different. On my SC, the wires are long but you can also pull that loom through a bit around the fuel tank area. You may have to loosen a few of the metal loom tabs.
To be honest, the only reports of wires being too short are on this forum. Dozens of shops fit these panels everyday.
www.classicretrofit.com |
Vinyl guru ask 4 a quote
I like mine, anything to get rid of the bullet fuses....
1983 cab. 3,6 lots of other stuff. Now the daily driver. 2012 Mercedes ML 350 Parked. |
ROW '78 911 Targa
I’ve seen many short and long tied and terminated fuse panel wires, depends on who tied it at the factory.
The joys of hand built cars. I’ve installed more than a few of Johnny’s fuse panels on new harnesses, never a problem with too tight terminal holes when using new ferrules. Plus, I generally use larger gauge wire than Porsche did, so they take up more space in the holes.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI. Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. |
82 911 SC - Ancora Imparo
At some point I will rewire the car and clean everything up to match the high level of quality of the CR fuse panels!
Ethan P-car: 1982 911 SC - Wine Red Metallic Coupe PB&J Murica: 2017 Corvette Z06 - Watkins Glen Gray Metallic |
Thread Tools | |
Rate This Thread | |
