starting engine after 4 years
I found a guy who has a 3.0 engine sitting in his barn after buying a pair of Fuchs from him. He told me its from his brothers accident damaged SC and is complete except for the fan/alternator. Naturally I want to take it off his hands but it has been sitting on the pallet for four years.
It seems prudent to me that this motor will have to come apart for inspection, but then I was thinking if the oil was changed, fan replaced etc, etc and the motor was cranked over manually would it be feasible to start it. Has anybody ran an engine after such a long period of inactivity? |
My cousin had a 3.0 engine that was sitting in back yard shed for 2 years. He had bought from a junk yard it as a spare for his SC.. He crank it once in a while and squirting oil to the piston thru the spark plug hole. He ended up having to use the engine but before he had install it he put new valve stem seals and did the valve clearances and bunch of other things. I heard it run but smoking form the oil on top of the piston. It sounded good and ran good.
78 911SC |
check for rodent and make sure all external moving parts work. My car that sat for a year had a nest over the cooling fins and nearly seized throttle bodies. I'll let ya know more when it's on the road
(see my story tomarrow)
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
The biggest concern is rust and water accumulation.
There may be better ways, but this technique is a good start [pun]. - drain all fuel lines - dry 'em out completely before adding fresh gas. - Install new fuel filter/s - remove the distributor cap. - Spray lots of WD40 into each cylinder. Crank for 30 seconds. Wait a day or two. - Squirt a couple of ounces of oil in each cylinder. Crank for 30 seconds. Wait a day or two. These steps should clear any corrosion. Now you are ready to try to start it. Once you get it started [don't run it to full temp the first time, its time to drain the oil, replace the filter and start it again. Now you should be ready to see what you've got. You might be surprised at how well it runs. Hope so. Good luck - even 3.0s deserve a good home
Tony K '89 944T 944 SuperCup Champ 2004 & 2005 '85 Carrera - Sold [sob] TrackVision 944Cup The 999 Site |
check the head studs, especially on the SC. I bought my euro motor and pulled off the fan housing and found the rodent nest too. Pulled the valve covers and tink, tink, two head studs fell out. Good thing too, as we replaced the studs with racewares and did the top end, we found the valve guides worn a bit. It seems that the European fuels may have contributed to the guides wearing out. Runs like a new dog now.
John Brasfield 91 C2 78 SC For sale 76 3.6 68 Datsun 2000 Mr. Magoo, 02 330ci |
I am going to make a return trip to see this engine again armed with a few tools and crank it over by hand and have a more in-depth look. Obviously the fan/alternator will have to be replaced and some CPR performed but there is no reason why this motor will not run on the pallet, is there? Heh -I didn't consider the possibility of rodents fowling up the airflow in the fan housing. |
I bought a '77 2.7L from a guy a few years ago that had been stored in his garage. He said it was in really good shape. I was going to rebuild it anyway & took apart. Turned out his kids (or somebody) had poured dirt into two of the cylinders. It wasn't apparent just looking at the engine, but it sure wouldn't have ran that way.
Marv Evans '69 911E |
completely filling the engine with oil for a few days might save the valve guides
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday |
