| Driven97 |
10-01-2015 04:53 AM |
Originally Posted by Bill Verburg
(Post 8816804)
the rebuild and install should be handled by a competent shop, GT has a list of shops that they deal w/.
This is important and should not be overlooked. Shims down to .05" (half the thickness of a sheet of paper) are used to adjust the total width and lateral position of the diff. Total width is for the preload on the cone shaped carrier bearings - too tight and they'll wear prematurely, too loose and the ring gear can shift under load. The lateral position is for the gear mesh between the ring and pinion. Too close or too far and they'll wear out very fast. Even very small production differences can make a big impact, so you can't just bolt a differential in without setting this up properly.
Pinion depth is even more complicated to setup, but if you already have a working R&P in the car that shouldn't need to be touched.
Originally Posted by vintagecarlover
(Post 8817707)
Can you explain what u mean by break away torque and how can that change by the way it's set up?
Break away torque is similar to the "initial" setting in the GranTurismo games if you play that. It's how much lockup the diff has when there is no torque applied between the input and output - aka when you have the clutch in. It's usually adjusted by a preload spring, that squeezes the clutches together. In this photo it's the dome shaped (Belleville) washer on top of the stack of clutch discs:
http://images.thesamba.com/vw/gallery/pix/876329.jpg
