1987 3.2 ECU removal
Can someone please advise how to remove the main ECU harness connector? I can't seem to release the inboard end (closest to tunnel). Looks as if I should pull it towards me (away from tunnel) once outboard end is released, but I'm afraid I'm going to break something if this is not right.
Thnx |
The outboard side (OS) has the latch and the inboard side (IS) has a hook. Unlatch the OS, hinge it toward the front of the car and then pull the IS to you (outboard).
___________________________ Patrick 1987 Carrera Coupe (mostly done) 1974 BMW 2002 (new project) www.brokenboomerang.com |
OK. Will do. Thanks
