-   -   Dansk Muffler Mod Question (http://forums.pelicanparts.com/porsche-911-technical-forum/885163-dansk-muffler-mod-question.html)
Frazer Douglas 09-30-2015 11:58 AM
Hi all, I have an '87 Carrera with stock everything including cat but I'm fitting an early rear bumper that seems to be complicating things somewhat in my search for a new muffler.
I'm hearing that M&K mufflers won't fit with early bumpers, so now I'm looking at buying a single in/single out Dansk muffler, cutting the tailpipe off and welding it up, and then welding two 50mm dual center pipes RS style on.
The question is can you just weld two new pipes onto the muffler without affecting the baffling / effectiveness / muffler performance etc?
And in doing so am I risking it being very loud with the new twin center pipes?
Not understanding the internals of mufflers, is this sensible or is there a single in/RS style dual out that would bolt right on to save modifying ?
Thanks in advance
toddu 09-30-2015 04:48 PM
I think the way the internal plumbing works, it won't exactly be that simplistic. There are some pics on here of the internals.
Todd
carrerarsr65 09-30-2015 06:38 PM
muffler
i just got done modding a 2 in 1 out,to a 2n2 set up ,cut off drivers side exhaust tip,then took my drill out with a new hole saw bit a made 2 2.5inch holes,then go to local auto zone bought a piece of 2.5x11 length cut that down i think to 5 inch length,then had a buddy weld it up the conversion cost about 35 bucks sounds good,and has the 911st look i wanted ,i'll post a pic soon
toddu 09-30-2015 07:09 PM
Sure, it'll make noise, but I don't think it aids performance if that's what you're after without dealing with the internals.
Todd
will hung 10-06-2015 01:07 PM
Can we get a pic of your mod? I really like the idea of doing this to my 2in/1out, only I might make it a 2in/3out like the old style rally mufflers.
carrerarsr65 10-07-2015 06:19 PM
video muffler
https://youtu.be/Hgge_AyI4bQ
couldn't figure out how to upload video so here is the http address where it is published.
tdw28210 10-07-2015 07:11 PM
Good work. Looks/sounds good to my eye/ear. Koni shock tubes reportedly work well as the tail pipes too.
will hung 10-08-2015 06:25 AM
Very cool. Thank you for sharing. Looks like I'm adding another project to the winter project list. I was going to mod mine to be more of a pea shooter, but I like the RSR exit a little better.
carrerarsr65 10-08-2015 09:10 AM
hey
thanks will,i by no means am a exhaust expert,but my butt dyno says it pulls a little harder up top,pretty straight foward mod. got any ??s ,i'll help any way i can al from mass
Frazer Douglas 10-08-2015 12:29 PM
That sounds great. Anyone got sound clips or video of a 1in that's been modded to RS style twin pipes (50mm or similar) with stock cat and heat exchangers?
Dave Kost 10-08-2015 01:43 PM
Here is the method for modifying 911 muffler
http://forums.pelicanparts.com/porsche-911-technical-forum/315409-homemade-sport-muffler.html
Frazer Douglas 10-09-2015 07:57 AM
Thanks Dave yes I've seen that diagram and this is exactly the mod I'm having done now. My car already has a twin pipe mod but it sounds like a power boat so I was hoping someone with the RS dual 50mm center pipes mod on a 1in might be able to give some idea of sound.
